Page 72 of 125
Posted: Tue Jun 30, 2015 10:15 pm
Awesome brother, looks good.
Posted: Wed Jul 01, 2015 6:21 pm
by 85_Z31
This is so good
So its nearly proper drive able soon ? Man i hope i didn't fuck up your spring calculations haha
Posted: Thu Jul 02, 2015 7:32 am
Yeah nearly proper drivable once I sort out the brake bleeding... they've used of the shelf springs which are still very firm otherwise I'd need custom coils
Posted: Tue Jul 14, 2015 8:42 pm
Posted: Tue Jul 14, 2015 8:59 pm
That is a sweet bench Greg. Pity it doesn't have a vice though. (yet) I fully rate that Homack stuff. (even though mine is still in the box)
Sorry I ran out of time to finish your half shaft.
Posted: Wed Jul 15, 2015 9:56 am
Sure is Bart! Yeah a vice would be perfect might start looking for one even if it's a small one. All good man I'll get that shaft for the lowrel sorted eventually
Posted: Thu Jul 16, 2015 12:35 pm
Posted: Thu Jul 16, 2015 5:13 pm
I think from memory one of the nuts is quite long and then there's a locking nut on it and it's just a clevis pin you need for the Y piece, you can get them from ISL. If they're the same James might have the bits on the Z31 crossmember I gave him? If not I might have them at home.
Posted: Thu Jul 16, 2015 8:54 pm
by brocky41
Get the new shorter shocks from work (probably hilux? i had mitsi pajero rears in the back of the y lol) - too much mucking around with those.
just make sure you throw in ones that either have the dust shield like what you have or put a rubber boot on like the 4wd ones (even rack boots work cable tied on) on the rear they get alot of stones and the like chucked at them from the front.
Posted: Fri Jul 17, 2015 10:05 am
Yeah been looking at work again today. Looks like some from a suzuki s410 fronts will do the trick have the dust shield on just need to check the bush at the bottom. Sweet djz I can get clevis pins from work pretty sure we have em on the shelf. Any ideas on where I'd find a long nut thing for that threaded adjuster? Or is a pick a part mish on the cards...
