Page 74 of 75
Re: DJZ's 280ZX
Posted: Wed Feb 27, 2019 2:36 pm
Re: DJZ's 280ZX
Posted: Sun Jul 28, 2019 9:38 pm
Got some other bonnet latches for this after all the trouble I've been having with the small ones, the new ones are 1.75" OD and use an 8mm thread where the small ones were 1.25" and used a 6mm thread. Need to make much bigger holes in the bonnet to fit them but hopefully they'll stop it from popping open.
The fuel rail needs a bit more dicking around with, I think I'm going to weld -6 fittings to the ends instead of using the threaded adaptors. Also need to get another fuel pressure regulator, they make a Nismo one like what I'm already using but with AN fittings on it.
Re: DJZ's 280ZX
Posted: Mon Aug 19, 2019 6:52 pm
Got this back from storage on the weekend, need to get a couple of things sorted before the Nationals.
I've got the new bonnet latches which look okay, they aren't that much bigger than the original ones which is good. I also want to make a box to go around the air filter and possibly change the inlet pipe to the turbo, change the injectors (maybe if I've got time), make a proper coil mount bracket and maybe add a water/meth kit.
Re: DJZ's 280ZX
Posted: Sat Aug 24, 2019 10:03 pm
Got the new latches in, had to make some bushes so I could use the hole saw in the original hole, worked out well though. These ones are long enough that I can use the locking rings with them as well, which I couldn't do with the old ones due to the thickness of the bonnet.
Re: DJZ's 280ZX
Posted: Sat Oct 12, 2019 7:17 pm
Took this out to work with the Z Club a couple of weeks ago, went fine.
I finally did something I've been wanting to do for ages which is replace the aluminium intake tube that I had with a carbon one. I had to rotate the pipe with the blow off valve on it around which I've also been meaning to do for a while, that meant trimming the adjuster bolt for the power steering pump and moving the boost source for the boost control solenoid, I made up a new boss at work and James buzzed it on for me.
Re: DJZ's 280ZX
Posted: Tue Oct 15, 2019 4:04 pm
by broke
Fancy. Did you make that CF intake tube?
Re: DJZ's 280ZX
Posted: Tue Oct 15, 2019 4:13 pm
broke wrote:Fancy. Did you make that CF intake tube?
Nah, I wanted to but with the amount of dicking around making molds and stuff like that it was cheaper just to buy one. We've got some good carbon guys at work now so the finish would have been better if we'd made one.
Re: DJZ's 280ZX
Posted: Wed Oct 16, 2019 10:38 am
by gingofthesouth
What's the specs on that turbo?
Re: DJZ's 280ZX
Posted: Wed Oct 16, 2019 10:41 am
gingofthesouth wrote:What's the specs on that turbo?
It's a GT4088R.
Re: DJZ's 280ZX
Posted: Wed Oct 16, 2019 11:40 am
by gingofthesouth
DJZ wrote:It's a GT4088R.
Big boy pants required.
