So while I'm sitting at home I thought I may as well start to get this ready to fit some of the bushes I've had sitting around for maybe 10 years and try and sort out some of the other little issues with the rear end.
The bushes I've had sitting around for ages were the rear arm bushes, I also got some Z31 subframe bushes that need to be modified to fit, I've started modelled up a new diff mount which I'll make when I get back to work, I still need to decide on what bushes to use for it. The front subframe mount pins are smaller than the crush tubes in the Z31 bushes so I either need to make new crush tubes or new pins, I'm leaning towards new pins.
I want to loosen up the diff a bit so James has that at the moment, also the axles have never been retained properly, one snap ring was missing and I think the other one is in the wrong position to suit the axles. I've ordered two of each type of snap ring, on the axle or in the diff and will figure something out when I get the diff back.
Also need to have a look to see if I can improve the companion flange to body interference on both sides. I would really like to do a Porsche CV conversion, but the car at the moment doesn't really need anything changed. I need to measure one of the Z31 companion flanges to see what the diameter is to see if they are bigger or smaller than the 100mm CVS, I could move the Porsche CVs in or out a little bit to help with the clearance.
I've also been thinking about selling the Z31 that I bought, as much as I like it I don't really need it.
