Got pulled over AGAIN!
I think each cop in town is checking me twice each to make sure im not breaking any laws (at the time)
Just checked us and sent on way.
SATURDAY:
Get mates crane truck, Roll Vanette over, Rape it or all goodies.
Result - I have a very dirty but virgin A15 engine ive half dis-assembled.
Im getting another mates Engine Stand tonite and will continue the strip show.
Kaylim’s 1978 Datsun Sunny of earthy tones
- Josh
- aka: SeEn-ThE_lIgHt
Re: Josh's 1978 Datsun Sunny, Diff in the back y0!
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
you mean you have more than one cop down there?
I DO ALL MY OWN STUNTS
I was thinking that with the kms on that donor A15, it'd really be getting ready for a valve job. But doing a valve job on a (well) used motor will cause it to become an oil hog. So it'd really need a rering too. You could chuck that cam in it, but aside from that it sort of has to be all or nothing with used motors.
- Josh
Its fuckin mint aye. But it appears that someone has overtightened the head as front and rear cyls had gone oval. Pics later maybe.
Its on a stand and prety stripped
- mint16
- aka: Brendan
Say what?SeEn-ThE_lIgHt wrote:it appears that someone has overtightened the head as front and rear cyls had gone oval
- Josh
Steel crush/firing rings have ovalated forward in the front cyl, and back in the rear cyl.
Pics when im not flat out
Also, broke the crank pulley (and its still not off)...do A series share the same one? ie can i rob an A12/J15 i have in 'stock'
- mint16
- aka: Brendan
the crush rings on a-series headgaskets are ovaluated from new, i dont know why but thats how they are.
so no head overtightening issues
Crank pulleys are the same through a12/a14/a15.
I have a couple of pullers to get the crank pulleys off. Have you removed the slugs? Are there any verticle scratch marks/scoring on the skirts? If a motor gets overheated badly, the piston grows in the bore, and all the oil gets forced out from between thre skirt and the bore wall. This wears the piston, and can lead to skirt failure. But A series motors gizzards can take a fucking and keep on trucking! If you remove the pistons, remember what I told you about the ridge in the bore. If the top ring jambs on the ridge in the bore, it'll damage the ring land on your piston, and although it may still be reusable, you'll suffer from blowby. (Which is uber gay) And any combustion gas which blows past the rings it lost horsepower..............
- Josh
Its absolutely mint then!
Just a bare block now, the smallest puller i had popped it straight off.
Bores, bearings, cam and rings are sweet..shouldnt have pulled it down!!!
Now its apart ill start cleaning and inspecting all super-sleuth like.
Brendan, thats awesome news! Weird as hell, but Awesome!
- Josh
Just at work steam cleaning everything.
