WRCDAT b110 13b rotary rallycar
- kobyn
- Datsun Mad
Re: my project (datsun 1200 race/rally car)
lil start up vid of the new engine http://www.youtube.com/watch?v=hBLChpi8 ... ure=colike" onclick="window.open(this.href);return false;
- R18dat
This has been one of the best projects I have read here so far, love the mod's. Hope to see it around.
- kobyn
- Datsun Mad
Thanks man . Just a update have had this extended fuel bowl made up for my ida seems to have fixed my fuel surge problem
Looks awesome dude will follow your lead once I step up to the next powerplant.
You can also take the top section off the ida and there is a cast webbing next the fuel bowl that can be machined out making the fuel bowl bigger , If you havent done this already.
Running a 48mm IDA?
Running a 48mm IDA?
- kobyn
- Datsun Mad
Oh yeah na i dont think it has been done yet might have to look in to that cheers. And its only 48mm for now anyways
- kobyn
- Datsun Mad
Started my 1st rotary rebuild today wasnt much to see inside there really isnt much to them
Seals in front rota still good wont know rear untill i get a 54mm socket and a big bar as tension on end nut is ment to b around 280-300 ft lbs
- kobyn
- Datsun Mad
Been pretty slack lately finish engine rebuild before Christmas was soooo easy. Done nothing at all on her this year apart from a few skids
Good work!
go the mazda !!!!
Rotary engines are cool !!!
must be a heap of fun !
- kobyn
- Datsun Mad
just got car back from my father inlaws workshop had some mods done to fit a new 3 core radiator and pair of electric fans also new uni joint and balance on the driveshaft last guy i let touch my driveshaft fuckd it up causing my gearbox to run a bearing n seal in the rear tail anyway got the pros to look at it and all sorted .
got a few events lined up at manfeild and a burnout comp in 2weeks in levin
