I've been really busy of late, but I still managed to get some stuff done. While the front wheels were in the air I swapped over to my good strut tops with the new bearings and fitted my Cobra springs - no more cut springs. It was at 85mm at the front before, it's just a little higher now. I haven't measured it, but should be at 100mm or more. Also fitted the new ball joint to replace the one that was completely knackered to the point that it had about 10mm of play!
Got all the timing belt etc off, was pretty stoked that TDC on #1 cylinder was literally only about an 1/8th of a rotation away from where the engine was when I stopped it, so I didn't have to spend all day cranking away at it before pulling it apart.
Figured I'd do this job one head at a time, it's a real pain because the power steering pump is bolted to one head and the AC compressor is bolted to the other one. Here's the side I've got off
Plenty of caramel milkshake there, but it wasn't bringing all the boys to the yard so I soldiered on by myself. Took the rocker shafts off, labelled them so I couldn't (hopefully) make a mistake reassembling it. Then took off the weird plate thing that house the lifters and then was finally able to access the head bolts. ALL 13 OF THEM!! I also learnt that there's a tiny bolt at the back of the block that holds the head on if you don't remove it, fortunately spotted it before I destroyed the head trying to pull it off! Got the head off and the rear 2 cylinders were full of coolant
I'm not really sure what the correct way to deal with that is, so I just mopped it up with paper towels and ended up with this:
Quite surprised at the lack of carbon buildup, and couldn't see any evidence of obvious gasket damage on this side (the gasket came off in one piece attached to the head) so maybe the other side is to blame. I'm not really sure the correct procedure for avoiding crap/corrosion getting into the bores, so I just wiped the cylinder walls liberally with WD40 then filled them with WD40-soaked paper towels until I get the head back on. This is what the bench at home looks like now
Taking the rocker cover and the lifter plate to work tomorrow to clean in the parts washer, and I'll take the head into Flemings unless someone recommends a different place?
