Page 9 of 19
Re: DJZ's other other 2 seater 280ZX
Posted: Wed Jan 07, 2015 10:18 pm
Yeah man, I think I've got another spare pair that I got off someone on here (maybe Adam?) that had the original flanges redrilled to 5 stud, but they might not even be Z ones. You can wreck things pretty fast with hydraulic presses!
Who has a set of companion flanges to suit CV axles that they want to give me? Or just one of them.
Posted: Wed Jan 07, 2015 11:19 pm
What size spline?
Nissan used two different sizes.
I have three sets of replica flanges.
Posted: Wed Jan 07, 2015 11:48 pm
by broke
And that's why all the yanks with 510s burn their bushes out
I've got the flanges off the C32 parts car still, they're 3x2 R31 style so a bit bigger than the R30/910 etc ones. Will they do?
Posted: Thu Jan 08, 2015 6:48 am
I've got a set of R31 ones, was hoping to not have to change the stub axles so small spline ones would be best. Bart, will yours be certifiable?
Posted: Thu Jan 08, 2015 9:56 am
Paint them black, who would know?
I don't really know if they'd need cert? They aren't actually a suspension part as such.
they're a uni joint style flange, with the square part turned off. then a new flange made up, spigoted on true, and fizzed together buy an extremely competent welder. (A mate of Dads who is a pretty accomplished welded) The beads look very nice too.
Posted: Thu Jan 08, 2015 12:30 pm
by kicker
DJZ wrote:
There was a whole 910 IRS rear end on Trademe the other day for $100 but the guy withdrew it while I was thinking about it, I would like to do CVs while the rear end is apart too.
Was it this one? Give him a bell
http://oldschool.co.nz/2011/forum/index ... -910-chch/
Posted: Thu Jan 08, 2015 12:31 pm
Yeah, I asked him and he said he sold it to his mate. Bummer for me!
Posted: Mon Jan 12, 2015 8:59 pm
So an R180 clutch LSD just happened to pop up on Trademe, it's a later model K stamped 4.11:1 diff, not 100% sure what it's out of but it's probably a Subaru STI diff.
Has anybody swapped the bits the axles bolt to into an LSD centre? I've seen pictures of it done to an open centre.
Posted: Tue Jan 13, 2015 9:42 pm
by Jabo
You have got my attention.
I have a R180 VLSD 4.44:1 subaru diff that I have had sitting round for years. But I could never decide if it was worth the effort being vlsd and maybe the ratio is too high?
to get to my point I would consider parting with it if its any use to you. I have the subaru half shafts aswell
Posted: Wed Jan 14, 2015 7:07 pm
Probably not much use sorry man, I bought the clutch lsd, I can either use the original axles from the Z or some of the CV ones that I've got if I get some CV companion flanges.
Thanks man, I'll take all the help I can get.
I had another go at welding up my manifold bits after work and the water cooler for the torch really helped, previously the torch was getting so hot I couldn't hold it even with a glove on but now it doesn't get hot at all. I also changed to a gas lense which seemed to help as well. It looks ugly but I'm pretty sure it will seal, well enough for what I'm doing anyway. I could probably weld inside the runners too once I've ground it all out.
