Page 88 of 125
Posted: Fri May 06, 2016 12:24 pm
As mentioned above it's in someone elses hands to fix
Posted: Fri May 06, 2016 9:41 pm
by datsunboy
Bring it to my place if your friend has no luck mate.
Posted: Sat May 07, 2016 10:05 am
Pretty much sorted now! New horn relay so that all works now, the fuse for the tail lights etc was blowing because an earth was touching something it shouldn't, the headlight issue was caused by the relay working intermittently he said he'd get high beam to work properly once out of 10 tries or something like that I have a spare one at home so going to try that first before we go putting something different in
He was also going to check for current drop as I mentioned the battery was going flat so hopefully my alternater is still all good...
Edit: Also the wiper motor was seized so he took all apart lubed it up etc and it goes! Apparently it's a bit noisy so may need replacing at some point or it might come right with use. So on track for the 20th!
Re: Datto_610's 180B - Cert Prepping!
Posted: Sat May 07, 2016 11:59 am
Awesome Greg. It's fun to work on them, but nice to get them all sorted this quick
Posted: Sat May 07, 2016 12:46 pm
Sounds like he knew what he was doing, good result.
Posted: Sat May 07, 2016 2:09 pm
Yeah definitely! He's an older fella who's a wizard with anything mechanical and electrical it would seem!
Posted: Sat May 07, 2016 2:21 pm
by chris_g1
Nice work its all coming together mate.
Posted: Tue May 10, 2016 1:35 pm
by Godzilladat
Crazy to think this car is almost complete. I think you were just getting started last time I was in NZ (2008), and looks like you'll be completing it the same year i come back!
Thanks for sharing the details on the fixes to the issues, my old mans 1600 has a few wiring gremlins that need sorting and I think the relay and earth one might help his headlight issue.
Posted: Tue May 10, 2016 6:10 pm
No worries dude! Yeah I can remember when you came all the way over here will be good to catch up when you're back too!! Should be picking it up tomorrow with the electrica fxed and then just a few things left and a general tidy up!
Posted: Tue May 10, 2016 6:17 pm
Then skids!
