I'm on the lookout for more RB26 throttle bodies for this thing, they're getting a little bit hard to find.
I spent a few hours on Sunday removing the subframe mounts out of the parts Laurel, I got the front two out by just cutting them out, with the rear ones I thought I'd try and remove the spot welds and pull the panel they were mounted to in one piece and fit this to the Z as I've seen this done on one in Japan, except it was a brand new piece from an R32 which you can read about here http://www.takkun.net/dri-z-324.html. I haven't managed to get it out yet but I will one night this week.
DJZ's other 280ZXs
Re: DJZ's other 280ZXs
I'm sure with all your skills you could scan and 3D print oneDJZ wrote:Now if I could just liberate one of these from work I'd be 90% there.
Finally managed to get the rear subframe mounts out of the parts Laurel, what a nightmare. I wouldn't try and remove it in one piece next time as it didn't work very well this time, I'd just cut them out.
I mostly finished the model for the throttle body adaptors apart from somewhere to put the injectors, I've given the model to one of the guys at work to 3D print out of plastic so I can see what it looks like and make sure it's going to work.
We got rid of the compressor in the machine shop at work so I've got a bit more room there so I'm going to take the V8 to work on Friday while I've still got the HTC ute. I've spent quite a lot of time looking at what I can use to replace the broken bits on it - unfortunately the VK56 thermostat housings which are a lot slimmer don't fit on the VK45s so I'll have to get another 45 one. I think the rocker cover is saveable, will try and find someone to plastic weld it.
Not very exciting but I got the new non hydraulic fan water pump for this thing from eBay.
Took the sump off the VK today and it looks like it's doable, I think I'm going to have to make a sump flange about 25 or 30mm thick and put two ports in it that run out the front or side for a remote filter mount. The engine itself looks pretty clean on the inside which is good,
Those VK45 plastic thermostat housings are available new from Nissan ex-Japan from memory. Had to replace one on a customers Fuga at work
Unfortunately it's this whole monstrosity that I need.Datto_610 wrote:Those VK45 plastic thermostat housings are available new from Nissan ex-Japan from memory. Had to replace one on a customers Fuga at work
Bugger... not easy to come by I imagine..
My new cam angle sensors turned up, that's about all I've done on this in a while. Need to get the sump flange pattern sorted and buy some ali to make one out of.
