Page 94 of 125
Re:
Posted: Thu Jun 02, 2016 11:36 am
by Godzilladat
Datto_610 wrote:That's pretty cool!
Agreed, I think it's brilliant in it's simplicity and design.
Datto_610's 180B - Cert Prepping!
Posted: Thu Jun 02, 2016 8:12 pm
After a lot cursing and nearly giving up I managed to screw in the bundy tube clip in! Borrowed a flexible drill attachment but couldn't get enough pressure on it for it to grip
so after trying to make a dint with my center punch, trying to drill a hole on a massive angle I managed to get a self tapping/self drilling screw to work!
Hopefully one is enough that is all he mentioned I needed anyway.
Got my steering lock stop bolt zinc plated and fitted that too!
Dropped gearbox x-member off to Wal for strengthening so should have that back soon!
Posted: Sat Jun 04, 2016 6:49 pm
This is the boot that was screwed to the trans tunnel which Ian wants me to replace
Knowing it was going to be damn near impossible to find an exact replacement, I trawled trade me and the Internet and managed to score a S13 Silvia boot off a facebook page got it cheap enough so I deemed worth the risk. Which was good because it paid off!!!
The only slight downside is that it didn't come with the metal ring that screws down over top of the rubber bits. A bit disappointed as I did ask if it came with it and I was assured it did but I didn't know it was coming with the bottom boot/gasket so it's not that bad I guess.
Already started marking out my own metal retainer ring out of some steel I have at home. This is as far as I got as there's going to be a lot of grinding and I had already had enough haha.
Posted: Sat Jun 04, 2016 7:51 pm
Have just found some ali sheet which will be much easier to cut so may abandon the 2mm steel for the mean time
Re: Datto_610's 180B - Cert Prepping!
Posted: Sat Jun 04, 2016 10:09 pm
by 85_Z31
I've got that big hole saw set if you want to borrow it ?
It goes up to some quite big sizes like 120 or 140mm i think
Posted: Sat Jun 04, 2016 11:02 pm
Took me a while but managed to cut it out of some ali sheet with tin snips. Was a mish cutting out the middle but I did it just need to finish off sanding /grinding the sharp edges off
Posted: Sat Jun 04, 2016 11:04 pm
by broke
So close to legal now! Good work Greg
Posted: Sun Jun 05, 2016 12:09 am
by chris_g1
Great work mate you'll have in on the road soon the very guy seems very picky one guy down here is terrible. He wanted me to remove the engine and bring the bits I welded so he could X-ray them. At my cost. Needless to say I didn't take either of my cars to him the guy dad and I use now is very fair gotten to know him now he's a bit slow but we can't win them all aye. Great work keep it up.
Posted: Mon Jun 06, 2016 6:28 pm
Posted: Mon Jun 06, 2016 8:19 pm
I would have my reservations about those mounts ability to isolate vibration from the driveline.
