Sorry about losing your ride height, i was so focused on prep that i forgot to take a measurement.
Well today was re-check day! Still not quite there though
plus side is all that needs doing is to dial the camber in a bit more as it's at about -2 degreees at the moment.... I'll get it adjusted with another wheel alignment at chamberlains to like the -1 degree mark and then it's all done! Will be on to that asap!
Is that all you failed your recheck on?
It was my understanding that cert guys could pass a car with greater than the threshold, if they believed the tyre's contact patch wasn't compromised?
Yeah that's all it failed on. Well he reckons -2 deg is excessive which I can understand also when you give it the boot the rear squats down and the tyres hit the inner gaurds I think he's more worried about that. But I called chamberlains this morn and apparently I'm at max adjustment on camber...... taking it in on thurs so will see how that goes.... I'm thinking maybe stiffer springs would help with the squating?? I'll keep you all updated.
Re:
I'll be watching this closely... good luck!Datto_610 wrote:Yeah that's all it failed on. Well he reckons -2 deg is excessive which I can understand also when you give it the boot the rear squats down and the tyres hit the inner gaurds I think he's more worried about that. But I called chamberlains this morn and apparently I'm at max adjustment on camber...... taking it in on thurs so will see how that goes.... I'm thinking maybe stiffer springs would help with the squating?? I'll keep you all updated.
Theres a bit more to it than that, ahve a read thorugh this http://www.lvvta.org.nz/documents/infos ... _Guide.pdf" onclick="window.open(this.href);return false;Bartman wrote:Is that all you failed your recheck on?
So yes the ceret man can approve greater camber than factory but only if he is satisfied that it all performs OK in regards to the following:
2.2(2)(a): “Steering mechanisms and their mountings, or any systems by which a driver controls the direction of a vehicle, must provide the vehicle with safe, efficient, convenient, and sensitive control.”
2.3(8): “Low volume vehicles which have undergone significant changes to the suspension system must feature no abnormal suspension geometry, and be aligned so as to provide satisfactory handling characteristics, and ensure against excessively shortened tyre life.”
2.4(1): “All modified production low volume vehicles with modified suspension systems must perform in a manner which preserves at least the quality of steering control which could be reasonably expected when the vehicle was originally manufactured.”
The way i remember on your sub frame kit the slots were already quite long for the camber adjustment ?
It might need to be raised in the rear a tiny bit, like a rubber spring spacer or such. Is there any room to file out the adjustment slot any further ?
