Turbo Oil Drain
Posted: Sun Sep 19, 2010 1:28 pm
Well its getting very close to the time when im going to have to get off my arse strip my L18E and put it back together with new rings bearings valve guide seals etc. (mainly i just don't want the bastard to leak on my new paint).
Well what i was thinking while its al apart and i have to move the dip stick to the rear hole as im changing sumps maybe i should drill and tap the front hole (existing dip stick hole) for a oil return.
I don't really have any plans of turboing the motor but things like that have been known to change as years go by.
So what i was wondering is if someone can recommend if.
A: Is it a good idea
B: What size thread should i get it tapped to??? (i'll just put a bolt in it when its not in use).
Thanks
Brett
Thanks
Brett
