Rotary Summerdrags
When: Sunday 31st October
Where: Fram Autolite Dragway - Meremere
Gates open at 8am
Scrutineering until 11.30ish
$40 to race / burnout or park in the pits - All entries on the day
Pit parking is open to pre 85 cars & rotaries only. No V8's or new cars
$20 spectators
Under 10's free
NO EFTPOS at the gate
NO DOGS or ALCOHOL
Yes there will be a wet t shirt comp again - $500 bux prize money so anyone who's keen on entering flick me a message or email tash@ontrackpromotions.co.nz
To race you must have:
A WOF or Tech Cert
A Scatterblanket or Scattershield
A Helmet
A Bonnet
A Restricted drivers licence
and be covered from head to toe just the same as Nightwars etc
Scruitineering is overseen by an NZDRA Scruitineer, so our guys will be under his instruction
For those that need scattershield specs
All Rotary powered cars - the shield described is mandatory minimum.
Where used, flywheel shields must be constructed so they completely surround the bellhousing to stop material entering the drivers compartment in the case of clutch failure. The shield should be constructed from 6.mm (1/4") steel plate, and extend forward to a point at least 25.4mm (1") ahead of the flywheel, and 25.4 (1") to the rear of the clutch and pressure plate. Shields must not be bolted to the bell housing and should attach securely to the "preferred" frame / chassis or engine. SFI spec bell-housing blanket is acceptable in place of shield. All vehicles running under 10 seconds must be fitted with a steel bellhousing.
