Page 1 of 2
180B Offset Strut Tops
Posted: Sun Jan 09, 2011 6:16 pm
by Mikewazowski
G'day team, I'm looking for a set (or two) of offset strut tops to run in my 610 180Bs. I'm not sure exactly which 180Bs came with the offset tops but they remove the inherent positive camber that some of the cars have.
Here is a picture of some of the tops in a car, showing how the shocks ends up pointing inwards instead of straight up.
Re: 180B Offset Strut Tops
Posted: Tue Feb 08, 2011 8:53 am
by Mikewazowski
Bump. Anyone know where I could find some of these?
Posted: Tue Feb 08, 2011 11:31 pm
by brocky41
Try The Mount Shop dude
Posted: Wed Feb 09, 2011 7:22 am
by Mikewazowski
Will do.
Posted: Thu Feb 10, 2011 12:31 pm
by Mikewazowski
I called up the Mount Shop but they reckon they only have 910 strut tops (which they reckon are the same as 610 ones). They couldn't tell me whether or not they are offset though.
Does anyone know if 910 bluebirds had offset strut tops? I would have thought they would have had longer LCAs so wouldn't need them.
Posted: Thu Feb 10, 2011 4:57 pm
910 strut tops are different they are offset but the bolt spacing is offset, so not what your after.
Posted: Thu Feb 10, 2011 6:15 pm
by torqued
Just get camberPlates and be done with it
Posted: Thu Feb 10, 2011 10:50 pm
by gingofthesouth
Posted: Fri Feb 11, 2011 7:30 am
by Mikewazowski
Was looking at those HSD kits, but decided I won't do that for now because:
- probably not going to adjust height anyway...just set and forget
- once I end up paying for cert it ends up being way more expensive than simple coil/shock combo which will suffice
I will probably go with camber plates if I can't find anything else but again:
- don't want to have to get cert for them
- don't really need to dial in much camber, just want to fix +ve camber and the factory fix seemed good enough to me
What's the deal with camber plates on top of datsun/R31 struts? I've only really seen camber plates used on top of coilover struts, can you still use them if you have spring which are the standard diameter?
Posted: Fri Feb 11, 2011 7:32 am
by Mikewazowski
Datto_610 wrote:910 strut tops are different they are offset but the bolt spacing is offset, so not what your after.
Cheers Greg. Thanks for clearing that up.
