WTB l20 electronic 4 plug distributor
Posted: Tue Feb 08, 2011 5:45 pm
by datrat
WTB l20 electronic 4 plug distributor anyone know of one lying around i want to block off the 4 plugs on the exhaust side of a Z20E+T and run only 4 on the inlet is this the easiest way to do it or should I be going down the ca18 cas mod route??
Re: WTB l20 electronic 4 plug distributor
Posted: Tue Feb 08, 2011 5:51 pm
by dirtyleppa
i would imagine finding an electronic dizzy for an L20 would be difficult at best. there is a thread on here, for converting a points setup to run electronic ignition on the L series engines.
Posted: Tue Feb 08, 2011 9:55 pm
by datsunboy
you could also just remove the second coil, and spark plug leads......presto.....its a 4 spark engine again.
remove the Exhaust side leads.....as I think those are the ones added that trail by a deg or something from the inlet side plugs to burn any unburnt fuel remaining
Posted: Wed Feb 09, 2011 7:20 am
by Mikewazowski
^ this.
Pretty sure the Z18ET can run with only the inlet plugs. Any reason why you only want to run four plugs though?
Posted: Wed Feb 09, 2011 8:33 am
by datrat
I have a broken 8 plug electronic dizzy where the cap bolts too cant find a 8 plug electronic dizzy anywhere either otherwise I would buy one
Posted: Sun Mar 06, 2011 12:46 pm
by unlimitedpower
My mate had a L18ET with a 8plug dizzy and the exhaust plugs arn't needed didn't run any different when when unplugged that coil.
