1600 parts clear out - so cheap your head will explode!
Posted: Sun Mar 13, 2011 12:04 pm
Hey guys,
Since selling the datto the old man has been on the warpath about cleaning all my shite out of his basement.
So all of the following must go - together! Will not separate! Will not freight!
The price is $100 (for all this) pick up from southgate wellington at your convenience - 0276638646
2x R160 housings and heads, with various bits enough to make up at least 1 diff - I'm sure at least one of the crownwheels will match one of the pinions.
2x 1600 rear a-arms (left and right) complete with brakes minus one drum. Nolathane bushes.
1X r31 skyline turbo strut + hub – these are the struts that have the 100mm calliper bolt spacing that allows the direct bolt on Nissan 4pot callipers (ONLY ONE STRUT!) also not sure which side it is..
2x 31 non-turbo callipers – I think these are something like ~80mm bolt spacing?
2x standard 1600 4speed gearbox x-members
5x 1600 halfshalfs
6x 1600 seat mounts – not the rails but the mounts that bolt to the floor and then the rails bolt to these.
1x 1600 complete seal rail (passenger side I think!)
3x 1600 headlight cages – the parts that the headlights are held to the car with. 1right have, 2 left hand. With 4 various headlights and good outer chrome rings ?
4x 1600 moustache bars
4x 1600 4bolt companion flanges – the 4 bolt flanges on the rear a-arms oh which the halfshafts bolt to.
1x pair of 1600 front radius rods (left and right)
2x 1600 rear KYB gas adjust shocks – are actually brand new and have no Km’s on them but don’t look it due to being taken in and out of a the datum several hundred times. – awesome shocks, very firm.
3x 1600 under bonnet lights
1x pair of R180 diff output shafts – the axels that come out of the diff, you need these if you’re doing a longnose r180 mechanical LSD + c.v. conversion. 3x2bolt pattern.
1x straight through 3”box muffler – this thing sounds amazing, only reason I took it out of the 1600 is because it was too low and scrapped on the ground :/
3x 3” stainless exhaust bends, 90degrees mandrel bent.
Various other bits – door mechs, window regs, hinges etc
Cheers guys - buy it!
Mikey
5x 1600 halfshalfs
Mikey
