Page 1 of 2
CA18de/det Throttle bodies
Posted: Tue Mar 29, 2011 5:53 pm
by nick_m
Hey, i need four CA18 throttle bodies. Can probably only afford one at a time though haha
Casting can be damaged as long as the spindle isn't bent and butterfly isn't damaged and the return springs/pulleys are in good knick. not too fussed on TPS only need one good one between the four
Let me know what you've got
Re: CA18de/det Throttle bodies
Posted: Tue Mar 29, 2011 8:01 pm
by dan1200sss
iv got one ca18det one, $20
Posted: Tue Mar 29, 2011 9:06 pm
by nick_m
sweet dude. I'll grab it off you when i'm out your way next
1 down three to go
Posted: Sat Apr 02, 2011 3:30 pm
I got one too man! Its yours, come round sometime and pick it up, still got your wheel spacer too.
Edit: Forgot to mention i dont have the pulley and spring on mine as i had to put it on my SR one. Let me know if you still want it.
Posted: Sat Apr 02, 2011 4:53 pm
by skdmrx
I got a 60mm sr20 one you can have so if any one wants a free bolt on upgrade for a ca18 you can swap it with them...Just make sure they die grind out the manifold behind it or no deal!
Posted: Sun Apr 03, 2011 10:07 am
by mint16
will sort out that tb i found on trademe for you, auction has ended.
Posted: Sun Apr 03, 2011 2:49 pm
by nick_m
Datto_610 wrote:I got one too man! Its yours, come round sometime and pick it up, still got your wheel spacer too.
Yeah all good. I'll still grab it. I think i'll only need one spring and pulley any way. I would come get it today but i'm way to hung over, so i'll pop round during the week for a catch up
How did you get on with that spacer? I'm probably not going to use them anymore so you can buy them off me if you want
Posted: Sun Apr 03, 2011 2:53 pm
Sweet dude, yeah spacer will work if i run 195 wide tyres. Just text me sometime this week and let me know.
Posted: Sun Apr 03, 2011 4:52 pm
by 85_Z31
skdmrx wrote:I got a 60mm sr20 one you can have so if any one wants a free bolt on upgrade for a ca18 you can swap it with them...Just make sure they die grind out the manifold behind it or no deal!
Sent you a PM dude I need a 60mm TB.
AND
If I somehow end up with a 60mm TB I have a 2 x Z31 TB's available which is 50mm ( I think ) and the same bolt pattern you can have.
Posted: Mon Apr 04, 2011 6:34 pm
by nick_m
ca's are 54mm so Z ones are no good unfortunately, thanks though
