Page 1 of 2
WTD: GLAZIER (chch)
Posted: Mon Aug 08, 2011 10:18 pm
by dmitry
Didnt know where else to put this, but is anyone, or does anyone know of a good automotive glazier in chch keen to do a cashy? I need 2x s110 windscreens removed one weekend, I'll sort the rust out another weekend and then one of the windscreens needs to go back in.
So whos keen?
Reply or PM or txt me. 027 349 4354.
Dmitry
Re: WTD: GLAZIER (chch)
Posted: Tue Aug 09, 2011 3:08 pm
by datsunboy
getting them out is easy!
we did it on my missus's 140J.......just use an old bike brake cable e.t.c. to cut it with.
probably best to get a galzier to put it back in tho
Posted: Tue Aug 09, 2011 7:54 pm
by dmitry
I have thought about trying to do it myself. How did you manage to take it out and hold it up without breaking? I really really dont want to break it!
Posted: Tue Aug 09, 2011 8:19 pm
by datsunboy
The process for taking out windscreens held in place by goo is as follows.
Push the bike brake cable through the goo.
once you get the cable through the rubbery goo, the rest is simple (but not easy).
by not easy, I mean that its tough work pulling the cable back and forward through the goo (we had 2 people, 1 inside and one out). wear gloves, or wrap your hands with a rag so it doesnt cut you.
you dont have to push on the windscreen at all while you are running the cable through.....once you have been all the way around, you just carefully gently push it out slowly, and presto.
If your windscreen is held in by a "windscreen rubber" like 510's (1600's), then Im not sure how you do these exactly, but dont poke a brake cable through them or you'll have to buy a new rubber.
I think those type of windscreens kind of "pop" out with a bit of persuasion, but Im not sure.
I think the S110 is probably of the goo type
Posted: Tue Aug 09, 2011 9:33 pm
by dmitry
Awesome thanks heaps, how did you initially pop the cable through? Fishing line may be easier? I'll have a look to see what kind of seal it is.
Posted: Tue Aug 09, 2011 11:26 pm
by datsunboy
You could try fishing line.....would make the cut easier i guess. Would need to be pretty tough line tho.
I think we just pushed it through slowly (bike cable is somewhat stiff)
Might have dug it out a little first, i can't remember it was over a year ago we did it lol
Posted: Wed Aug 10, 2011 12:13 am
by dmitry
Sweet thanks for your help man, much appreciated. Will practice getting the rear window out of my donar car and go from there
Posted: Wed Aug 10, 2011 11:22 am
by gingofthesouth
Just pusghed them straight out in my 510. Rubbers etc were intact too. They pop out without fishing line etc
Posted: Wed Aug 10, 2011 3:59 pm
by funkydato
I know of a couple, give me a text when you want them back in, I will talked to them, shouldn't be a problem for a cashy. David 0220251417
Posted: Wed Aug 10, 2011 7:12 pm
by dmitry
Awesome David, thanks a lot, will definitely be in touch, about a month away at a guess. Thanks for all the help!
