73 violet
73violet
Regular
aka: Phlex
73 violet
Post by 73violet »
ok so the 73 140j is a 710 right?
will a l20b and 5 speed from a 910 bluebird fit?
also my clutch bites really high, and being hydraulic i cant adjust it so im told.
a mate told me if i change the clutch master cylinder to a bigger one it will adjust the bite point down,
my question is which datsun has a bigger one?
also as far as seats go, are there any other 4 door datsuns with the same shape and size seats,
my ones are from an 81 sunny and they dont fit, i also have retractable seatbelts from a datsun ute of some sort which are more uncomfortable than wearing a womans g string to the beach.
73 140j
Slow and steady wins the race. But im sooo dam impatient
chube82
Regular
aka: chubbah
Re: 73 violet
Post by chube82 »
A clutch releasing high usually indicates the clutch plate linnings are getting low, that is if you have ruled out the hydraulic system at fault. A bigger master or slave wont change the fact that the clutch is buggered. :mrgreen: :beer:
73violet
Regular
aka: Phlex
Re: 73 violet
Post by 73violet »
ok cool. im hoping to be sticking a new 5 speed in soon so ill get a new clutch with that too
73 140j
Mikewazowski
aka: Michael
Re: 73 violet
Post by Mikewazowski »
73violet wrote:also my clutch bites really high, and being hydraulic i cant adjust it so im told.
Really? The clutch setup in my 180B is hydraulic and I have adjusted when it engages by adjusting the shaft that connects the clutch pedal to the master cylinder.
chube82
Regular
aka: chubbah
Re: 73 violet
Post by chube82 »
That is correct,But as i said this is if you have eliminated a hydraulic problem at fault,eg.master cylinder adjustment would be a hydraulic problem .
Less freeplay at master usually gives you a higher release point on the pedal,
More freeplay at master usually gives you a lower release point on the pedal.
Although you should not have to adjust master cylinder. :deadhorse: :highfive:
73violet
Regular
aka: Phlex
Re: 73 violet
Post by 73violet »
ill get under the hood an have a play with it one of these days and see what i can do.
73 140j
chube82
Regular
aka: chubbah
Re: 73 violet
Post by chube82 »
all good buddy :deadhorse: :gun:
