bit of a long shot but if any one has an EFI L series thermostat housing id be keen to grab it.
Main reason for wanting one is i need the extra position it has in it for the extra temp sensor needed for an EFI setup. so a hole for the temp gauge sensor and another hole for the ECU temp sensor.
Turns out putting your ECU temp sensor in a radiator hose does not work as it doesnt warm up with the engine, only when the thermostat is open.
Cheers.
Re: EFI L series thermostat housing
I've got spares somewhere but won't have time to have a look till the weekend.
- aka: 10 5
thats not a problem man, by no means in a hurry. cheers.
