FS: Datsun and loads of Misc stuff, have a look! - AUCKLAND
Posted: Fri Nov 25, 2011 1:33 pm
Please read all of section before asking questions. Will likely list most parts on Trademe in the next few days. May possibly have other Datsun parts kicking around I am willing to get rid of, worth asking but my stocks are depleting as I become less of a filthy Datsun part whore
PICK UP IS AUCKLAND - Will post most items at buyers expense, please don't ass me around getting postage quotes if you're not going to buy the item!
I AM NEGOTIABLE ON PRICE FOR MOST ITEMS, SOME NOT SO MUCH.
CONTACT ME VIA PM IF INTERESTED IN ITEM
Datsun A series 4 Speed Gearbox
56 Series. Came from behind my Datsun 1200 truck A12. Has about 80-90,000 kms on it so should be very good. Has been sitting for some time however. No selector or fork assem.
Can post at buyers expense but prefer pickup
$175 will take it
NEW ACL Protec Piston Rings for A15
Part number RS84034 - STD
New in box, never used
$60
Datsun Sunny B310 Steel wheels
4x114.3, silver, a pair
Have tires on them, something like 175/70 or similar large profile standard style tires. Medium tread from memory.
$50 for the pair
Also have a standard 12" Datsun 1200 steel wheels kicking about with tires if anyone is interested.
Datsun 1200 B120 B110 Heater core - Cranks the heat still!
No longer fits the tunnel I made for my SR swap. Good condition, brown cover plate otherwise rest is black.
Worked mint when the A12/A15 was still in there, no leaks. Was perfect in Winter getting out the 2 degree surf.
$60
SR20DE Standard Exhaust Manifold
Cast iron stock item. Twin exit. From an S14 SR. One of the studs has broken off.
$45
A15 Standard Exhaust Manifold
Cast Iron. Version WITHOUT the connection to the inlet manifold like A12 has.
$30
A12 Standard Exhaust Manifold
Cast Iron. Version WITH the connection to the inlet manifold.
$20
A Series timing cover
Stock item. Previous owner painted blue with crappy paint which is pealing off, would be easy to strip and make look like a crisp $100 note.
$10
A15 Standard Alloy Inlet Manifold
Version WITHOUT exhaust manifold connection
$15
LOADS! of Datsun 1200 truck door cards
Pretty much all of them are brown, some very good condition, others pretty average
$10 a pair
B110 Sway bar
Stock item, may have brackets but would have to look.
$20
A12 Backing plate - sandwich plate between gearbox and engine
The version which is a semi circle shape, not the full circle shape like A15.
Bit greasy but otherwise good to go
$10
A Series Rocker Cover
Can't remember if it has Nissan or Datsun in the top, could check for those interested.
Has surface rust but is restorable. Comes with oil filler cap.
$25
Misc stuff, make an offer
A Series oil pump
2" SU carb
2x B110 ignition coils
A series engine mounts
A series water pump pulley
Factory S13 radiator
B310 gearbox mount (part with rubber bit in it rather than the bit that bolts to the tunnel)
Get at me
$175 will take it
$60
$50 for the pair
$60
$45
$30
$20
$10
$15
$10 a pair
B110 Sway bar
$20
$10
$25
A Series oil pump
2" SU carb
Get at me
