I'm moving out in 2 weeks so think its time for a clear out. Have a few 180B parts and asst Datsun parts and some Nissan parts for sale.
Datsun Parts:
1 x 13'' Steelie tyre is stuffed $5
2 x 13" Steelies matching pair tyres are stuffed $10 SOLD
Throttle linkages from 180B may fit other L series models?? $5
Heater core and heater controls from 180B unsure if core is in good cond $20
180B manual pedal box may fit others $30
910 service manual free to a good home
180B choke cable and bracket may fit others $5
Chrome number plate surround $10
2x Internal regualtors from 180B both have different plugs $5 each
180B fuel flap no lock $5
Nissan Stuff:
Shortnose R200 LSD 5x1 axel stubs 4.11 ratio Local buyers only please!
Looks like it has been dropped at some point a few chips in the rear cover doesnt leak oil also missing one stud $100
CA18DET Turbo Manifold Heat Shield $10 SOLD
CA18DET Inlet Manifold Braces $10
Assorted RB and CA plugs and valves oil pressure sensors etc $10 for the lot unknown cond
S14 PFL Front Caliper(just 1) I'm pretty sure the other one is Barts somewhere if i can find it the pair will be $30 otherwise just $10 for the one
RB20DET Turbo oil drain $5 SOLD
T25/g/28 Turbo oil drain brand new never used $10 SOLD
Nissan bonnet struts x5 unsure of condition $20 for the lot
RB sandwich plates x3 the half one is a bit bent but should be easy to straighten $20 for lot
Nissan gearbox crossmember has an A stamped into it under the rubber mount unsure what its from $20 SOLD
CA brackets and under drive pully(I think?) $20 for the lot SOLD
Prices can be negotiated want all these gone asap so will biff out most of it it doesnt sell. Cheers
Datto610's Garage clean out
Re: Datto610's Garage clean out
I'll take the RB oil drain greg.
I'm failry sure I gave back the caliper? I'll have a look for it this week.
Sweet man, it could be at your mums place??
- aka: Dan
Well take the t25 oil drain Greg
Sent from my GT-I9100 using Tapatalk
Sweet Dan I'll bring it over next time I'm round
- Lang Inder
could you please explain how that big ca18 inlet manifold brace works? one came sitting in my silvia and i didn't have a clue wat it was
2x1972 Datsun 1200 B110 Coupe
2x1982 Datsun 180sx
2x1982 Datsun 180sx
- 240znz
- aka: James
Can I grab those two 13" rims off you? They are a off a Datsun aren't they? Saves me using the Z mags on the new trailer as they are probably better on a zed.
- aka: Dan
The big brace bolts to the underside of the manifold and to the block down behind the alternator.
The small ones go in around the fuel rail
Im keen on the manifold heat shield thanks.
There yours James, they came off my 180B so are the datsun stud pattern240znz wrote:Can I grab those two 13" rims off you? They are a off a Datsun aren't they? Saves me using the Z mags on the new trailer as they are probably better on a zed.
