Page 1 of 2
R31 Hubs options
Posted: Thu Apr 12, 2012 3:37 pm
by sr1600
Have some R31 hubs i cut the disc and machined the outside off to fit inside gtst brake discs as per the usual path, However i suspect now I dont have enough room between the back of the wheel and the caliper .
Now i got to looking at the z31 turbo hubs i have which are really similar dimensionally but have the disc bolted to the back of the hub, but they are 5 stud.
Is there any hubs in 4 stud that are of similar design as these? That I could mount the disc on the back of with the chance of gaining a little offset?
cheers
Re: R31 Hubs options
Posted: Thu Apr 12, 2012 3:48 pm
How hard would it be to redrill 3 stud holes and convert your 5 stud Z31 to 4?
Posted: Thu Apr 12, 2012 3:53 pm
by sr1600
the actual application of it would be easy
But i doubt the cert man would be happy with it due the area of the hub casting being built up around the 5 studs
has anyone ever done it?
Posted: Thu Apr 12, 2012 4:19 pm
Early non turbo or VG20ET powered Z31 hubs should be 4 stud, or 280ZX hubs have the rotor bolted to the back of them from memory.
Posted: Thu Apr 12, 2012 4:41 pm
by sr1600
Looks like some 280zx ones might be the go
Cheers - Now to track a pair down to measure for size against the r31 ones.
Posted: Thu Apr 12, 2012 6:52 pm
910 Bluebird hubs have disc bolted to the back of hub may be more common than 280zx.
Posted: Thu Apr 12, 2012 6:57 pm
I don't know much about the 910 hubs but do they take the big bearings like the Z & R31 hubs? R30 hubs might be another one to look at, I can't remember if they have bolt on rotors but I have a feeling they do.
Posted: Thu Apr 12, 2012 7:22 pm
by 85_Z31
You can actually get Z31 4 Stud hubs, you wont be able to re drill a Z31 5 stud hub into a 4 stud, they way its cast won't allow it as there is not much meat in between hole centers.
If you get desperate I have a contact who would be willing to send out some Z31 NA 4 stud hubs.
Posted: Fri Apr 13, 2012 8:41 am
by sr1600
85_Z31 wrote:You can actually get Z31 4 Stud hubs, you wont be able to re drill a Z31 5 stud hub into a 4 stud, they way its cast won't allow it as there is not much meat in between hole centers.
Thanks was really after a confirmation that they exist in two piece before i went looking for them
Willl have a look around local first
Posted: Fri Apr 13, 2012 7:46 pm
by spiderwebfx
S12 4 stud hubs also have a bolt on disc, that could be another option?
Edit/ they are also of a similar era to the Z31 so would be similar I'd imagine.
