FS: Race camshafts for A series and L6, Christchurch
Posted: Sun May 13, 2012 1:30 pm
Alright so I've got a couple camshafts here I was hoarding but will no longer need due to my job. I'm piss poor so going to sell them.
Kelford F77 for A14/5. 262/265degrees at 50 thou, .380"/.385" lift (on standard rockers). Huge duration, low lift - I think this is the old Nismo A12 82degree grind. Suits a fully built motor (at least 12:1), and I'd recommend higher ratio rockers if going in an a14 or a15. Has been polished, re phosphate coated and bagged up. Includes a Camdoctor report for specs. $150
Franklin Race cam for L28. 258degrees at 50 thou, .500" lift. Again I wouldn't run this cam on anything below 11.5-12.1: C/R. I haven't actually checked on a cylinder head but I think you will need thicker lashcaps to run this camshaft (to account for the reduced basecircle). Has been polished, re phosphate coated and bagged up. Includes a Camdoctor report for specs. $150
Both cams could be used in a street car with the correct combination of parts. Both will need to be used with refaced followers / rockers.
I also have a RE13 cam for a mini if there are any sicko's on here. $150
Rob
Rob
