WTB ca18de custom weber 4 port inlet manifold
Posted: Sat Jul 28, 2012 7:40 pm
by datso
Anyone have this one for sale?
Lawrence I recall got it?
Re: WTB ca18de custom weber 4 port inlet manifold
Posted: Sat Jul 28, 2012 8:14 pm
by nzdatman
That is an eight port manifold.
Posted: Sun Jul 29, 2012 1:22 pm
by datso
aha! thank you ! .....I was too
Posted: Mon Jul 30, 2012 5:39 pm
Just get some flanges laser, or water jet cut from Aluminum, and get the TIG'd on to the CA18 sub manifold.
Posted: Mon Jul 30, 2012 7:45 pm
by nick_m
^exactly. There isnt much too that manifold
Posted: Tue Jul 31, 2012 4:21 pm
I'd probably get the flanges on both sides cut, then Aluminium tubes welded between them. You never know how nicely the factory flange would weld. (I had a terrible time with an SC14 discharge manifold)
Posted: Sun Sep 23, 2012 1:30 pm
by datso
Just to let peeps know if you are making such a manifold its only possible on the 8 port head
The 4 port head has totally and incorrect location of ports in this area and I only found out
too late when I tried to place the weber flanges on.
There is a big bias on the 4 port head and makes it impossible to use the primary manifold.
regards, d
Posted: Mon Sep 24, 2012 8:17 am
datso wrote:Just to let peeps know if you are making such a manifold its only possible on the 8 port head
regards, d
were you trying to mate the factory inlet flange to a weber flange?
if so could you get a new head flange cut and weld tubes between the flanges as bart describes
Posted: Mon Sep 24, 2012 10:33 pm
by datso
yep will have to be all custom pretty much
will use factory flange to make a new one but ports are 62mm x 44mm which are massive ports
and the oval shape will be hard to taper into custom tubing but have no other choice as 4 port
heads dont come around often and worthwhile to hold onto.
