Hi guys,
Looking for an A15 Engine dipstick. Cheers.
Regards,
Braasy
WTB A15 Engine Dipstick
braasmonkey
- aka: Braasy
Re: WTB A15 Engine Dipstick
I've got an A14 (T) one, not sure if they are the same.
braasmonkey
- aka: Braasy
Worth a try/comparison if that's cool with you?classicdat wrote:I've got an A14 (T) one, not sure if they are the same.
- Braasy
Not a problem Braasy, just pop around when you're free
Where is your dipstick hole & what is your sump like?
braasmonkey
- aka: Braasy
See you in Octoberclassicdat wrote:Not a problem Braasy, just pop around when you're free![]()
- Braasy
I have taken some pictures but can't open them to edit. My tube looks longer than yours
My sump is about 150 deep where the Dip stick is, the tube is about 185 high and the dipstick, to the face of the rubber that seals on top of the tube is about 380 long. All in mm, hope this helps. If this computer decides to play ball this evening I'll try put up some pics.
Vaughan
Vaughan
funkydato
- aka: Pickles
thought a12 would be the same??
81 b310 Dato (everyday drive)
81 b310 Dato (in storage)
79 Sunny (project on-going)
Ministock (Green, 1200)
braasmonkey
- aka: Braasy
You and me both, but it would appear notfunkydato wrote:thought a12 would be the same??
- Braasy
Early a12 like in a B110 car has the dizzy at the front and the dip stick goes into a hole drilled into the block, Mid dizzy motors have a tube that comes up from the block, between the oil pump and the fuel pump as per Braasy's image. Early a12 dipsticks are solid wire, with the H-L area crimped flat, a15 is flat steel riveted on to a wire handle. The lengths are also different.funkydato wrote:thought a12 would be the same??
Early ones can get caught in the crank web if they are put in wrong, locking the engine solid on start up
braasmonkey
- aka: Braasy
Uh oh... Speaking from experience it would seem Vaughan hahaclassicdat wrote:Early a12 like in a B110 car has the dizzy at the front and the dip stick goes into a hole drilled into the block, Mid dizzy motors have a tube that comes up from the block, between the oil pump and the fuel pump as per Braasy's image. Early a12 dipsticks are solid wire, with the H-L area crimped flat, a15 is flat steel riveted on to a wire handle. The lengths are also different.funkydato wrote:thought a12 would be the same??
Bring on October...been itching to drive since I left... Hopefully I can check the oil levels properly when I get back
- Braasy
