1985 720 ute diff ratio, need to change my ratio
Posted: Mon Sep 24, 2012 7:30 am
Hi all , another newbe here.
I got my self a present in the form of a 1985 720 single cab flat deck ute.
Im going to have a go at doing it up, that part will be pretty easy as its in quite good shape.
My real problem is that it is running a 1600 4 speed colum change with a 4.8 diff ratio, I need a replacement diff, or can I change the ratios. 100k at ten million revs isnt that cool. if so where can I get the parts, is there a compatiable donner car ( maybe a bluebird of similar age) that will do the trick.
cheers andy
cheers andy
