Hi Guys
Found a whole heap more stuff i want to get out of my way in the garage so here it
More Coil over Springs $40 per set of 2 both pair are 180mm tall. I don't have the exact spring rates but I'm pretty sure both sets are 6kg mm
Red line LSD additive - Brand new un opened bottle. I ordered it before i drove my car and I don't need it because i do not get any clutch chatter.
Cost me $40
Eccentric Camber / Toe Bolts
These came of My Parts car & some suspension arms i bought a while back, these are factory Nissan Toe Adjustment bolts. They could be used to make an adjustable subframe and are the same length as 610 or 510 suspension arm bolts.
NOTE these would suit a setup only needing small to medium amounts of adjustment - but in saying these would be really easy to fit to a sub frame, all you need is a thin strip of metal each side for the eccentric cam to slide on.
I'm going to say $80 for the full set of x4 adjustment bolts. these are 14mm diameter not the usual 13.5mm so your inner sleeves will need to be drilled or reamed out.
Z31 Turbo bonnet scoop
I a few of these and this one needs to go , no cracks or dents, has old nasty paint on it but all 4 mounting studs are good. I would say its average condition but would come up mint with some preparation work. $60 because its so 80's badass.
Coilover springs, Diff additive, Eccentric Subframe bolts
Re: Coilover springs, Diff additive, Eccentric Subframe bolt
What the ID on the springs? looking for some with a 60-65mm id
they are Japanese Size so 63mm inside, so a shade smaller than 2.5"
Black Springs Sold
