Page 1 of 3
FITTING 15' MAGS TO 1600
Posted: Tue Nov 06, 2012 9:31 pm
by hsepwr
Re: FITTING 15' MAGS TO 1600
Posted: Tue Nov 06, 2012 9:40 pm
by illusive
Sorry for the big picture, But these are 15x7 0 Which struts are you running?
The Fronte do stick out a wee bit but nothing major.
I've just put some 14x8.5 on the rear with abit of guard manipulation
Posted: Tue Nov 06, 2012 9:57 pm
by hsepwr
I'm running 910 struts but tried them on a standard 1600 also with standard struts and they stick out just as much, how many mm's do you reakon yours stick out?
Posted: Tue Nov 06, 2012 10:12 pm
by brocky41
Hey dude, how much clearance have you got wheel to strut tube - if you have 35mm with the 7 then you'll need a +30 wheel to tuck the front back under - eg 15" 4 stud skyline is around that. Then spacers on the rear to suit unless you can get either of those wheels in a stagger fitment. (you probably already know this though)
The Minilite style is probably your best chance and you probably know suppliers??
palmside do these wheels in various sizes
http://www.palmside.co.nz/product_pcid_16241.html" onclick="window.open(this.href);return false;
Posted: Wed Nov 07, 2012 8:10 am
by sr1600
Hmm
Seems odd Craig what front hub are you using? Mine are a r31 51mm strut tube i think
I remember there were some spaced 30mm further in in the mounting point at the bottom when doing research on it
These are 15x8 +10 (i wouldnt think my camber plates make that much difference maybe 10-15mm at the most) I would have though +20 would of been perfect.
Had 15x8 0 offset on the rear also but there is a fair amount of massaging to the door jam to fit that
Posted: Wed Nov 07, 2012 6:21 pm
I hate to say it, but it might be the bluebird struts.
I had a VERY crude measure up before. Placing a ruler across the hub face, and measuring to the strut at 200mm from the center of the hub, I found that the 910 strut stuck out further that the pair of 280ZX struts that I also measured.
Posted: Wed Nov 07, 2012 7:13 pm
by torqued
Is it the hub or stub thats the offender Bart?
Posted: Wed Nov 07, 2012 7:29 pm
It's hard to say. I only had a quick look. After Craig rang me it piqued my interest.
Posted: Wed Nov 07, 2012 10:04 pm
by hsepwr
Bartman wrote:I hate to say it, but it might be the bluebird struts.
My 910 struts cant be any different to shanes standard struts as they stuck outside the guards the same amount I might give you a call at some stage to quiz you on what you measured if thats sweet
Posted: Wed Nov 07, 2012 10:47 pm
by brocky41
Are they factory lower arms and B/j's as i know the B110-B310 ball joints and arms can mix and match to make a longer (or shorter ) control arm - im unsure on 1600's though.
You could also do one of the below
