Page 1 of 2
VG injector issues
Posted: Sat Dec 01, 2012 9:34 pm
by broke
Hi people,
While driving my C32 with the VG20ET I noticed it started running very roughly, with a strong smell of fuel. Upon closer inspection the intake manifold was wet with petrol. Knowing that injector seals are a common problem, and wanting to avoid a fire I pulled out all the injectors and seals. The seals themselves didn't seem bad (they were still quite soft and rubbery feeling) but the pintle caps of the injectors where they go through the seals looked quite black. But having had a bit of a nose around the interwebs it seems that the injectors themselves seem to leak too. Is there any way to fix the injectors if they are leaking? And if not, are there any newer cars that run the same injectors? I know VG30 guys can use RB injectors, but I don't want to do that if I end up with different CC ratings. Anywhere (other than Nissan) where I can buy them?
Thanks in advance guys.
Re: VG injector issues
Posted: Sat Dec 01, 2012 9:50 pm
Does it have barb style injectors? Sometimes the hoses can leak and sometimes the injectors themselves leak from the bodies.
Posted: Sat Dec 01, 2012 11:58 pm
by broke
Yeah it does have the barb type top feed injectors, the hoses seemed dry but the bodies did seem a bit damp.. I am going to replace all the hose anyway as I can buy it for bugger all and I don't even need a metre of it. Do you know if it's possible to pull them apart and repair them if the bodies are leaking?
Posted: Sun Dec 02, 2012 8:06 am
Nah I'm pretty sure they are throw aways if leaking from the bodies. The only Skyline injectors that would go straight in would be red top ones as far as I know or possibly L20et ones might be the same size?
Posted: Sun Dec 02, 2012 9:35 am
by torqued
Ive got VG30et or L20et injectors if you want to do a deal of some sort
Posted: Sun Dec 02, 2012 12:05 pm
by 85_Z31
according to Z club.org.nz VG20ET injectors are 185cc min
VG30ET's are 259cc min
you could still use them if you lowered your base fuel pressure by the percentage difference.
Or perhaps Datsunboy could socket your ecu and burn you a chip to suit the vg30et injectors that Adam has.
Out of interest John, if my 2 sets of 30ET injectors i struggled to make up a set that didn't leak, in saying that i had a RB GTR injector go bad and leak on me also.
Posted: Sun Dec 02, 2012 12:21 pm
by torqued
L20E & L20ET injectors are 185cc's which should be a go then
Which I have about 18 of
Posted: Sun Dec 02, 2012 9:03 pm
by broke
Thanks for all your help guys, I'm going to get the injectors I have tested, if any show up bad then I might try the ones off my parts car, if they're bad also then I might hit you up for those L20ET ones Adam.
Posted: Tue Sep 17, 2013 10:29 pm
by navaraherb
Hey guys, i realise this thread is almost 12 months old but I'm having trouble finding injectors for my vg20et. Can you recommend anywhere i can purchase new ones or even second hand ones? Thanks in advance
Posted: Wed Sep 18, 2013 8:50 am
by torqued
l20et are the the same as far as i am aware
