2 doors
Re: 2 doors 1200 2door sedan / engine now RUNNING
Post by 2 doors »
hey Greg , stanmore road auto spares of all places.
Nice!
2 doors
Post by 2 doors »
Small update , the brake issue has been resolved , turns out the circlip holding the plunger had come out , letting the plunger fall out and the fluid followed , a close inspection also revelled a small tear in the seal, so that's been replaced as well.
I have planed the manifold where it mates to the head ,and reassembled the manifold and turbo etc with GASKETS, so hopefully it's all back together for the last time. Hope to start it this weekend , and may get to drive to the servo and back , oh and got this hard to find last piece of the puzzle, which was holding me back from doing stuff.
85_Z31
Post by 85_Z31 »
Nice work on the Oil Drain Wall
If you want to do some laptop wide band stuff at some point give me a shout and we can do some precision guesswork
2 doors
Post by 2 doors »
Update...... well the car is running again , and really well, which is great , there is no exhaust leak and it's making boost again .
However the brakes are still giving me issues , when I bought the new seal from bnt it was the same diameter as the old one but it was thicker , I was assured this would not be an issue but it is , after assembling everything and bleeding the rear brakes I discovered I couldn't bleed the fronts , I couldn't even get fluid out of the master cylinder with the vacuum bleeder , simply because on close inspection the new seal covers the hole that the fluid is supposed to drain down from, pretty pissed off to be honest. I will try butler's or safe r brakes this week , and see if I can get better service from them.
At least I get to hear it run again.
:burnout: Frustrasting!
2 doors
Post by 2 doors »
Yip Sure is
2 doors
Post by 2 doors »
Hey , I'm back with good news I think , so far the brakes are working again , thanks stanmore road auto spares for the proper seal kit.
I'm really quite close to driving to the servo for gas.
braasmonkey
Site Admin
aka: Braasy
Post by braasmonkey »
2 doors wrote:Hey , I'm back with good news I think , so far the brakes are working again , thanks stanmore road auto spares for the proper seal kit.
Hardly worth the drive for you ;) Definitely good news; am really excited to see you and this on the road soon Wal! :D Especially with working brakes haha
Well done Wwal. Sometimes it is the little disappointments that can grind things to a halt. Great to see you have pushed on.
I'd be keen to come see this running today and what else is going on in the shed. You about today?
