Can any one with an L series Six post a photo of there distributor as i have taken me one off to clean and now the "old girl" won't start.I've set the firing order to 1 5 3 6 2 4
Here's photo of the timing sorry for the bad pic
Help
- Ivan
- aka: Ivan
Help
Datsun 260c
Re: Help
Dizzy should only go in one way as the tang on the shaft is offset. Got the leads going the right way? No 1 should be closest to the radiator and they should go counter clockwise from there.
Got a timing light?
Got a timing light?
project r30
Re: Help
did you complete remove the dizzy?if so could be 180deg out.
- Ivan
- aka: Ivan
Re: Help
All good got the old girl running again
This what i thought the firing order is 1-5-3-6-2-4 Well it is but 1 wasn't were it should have been
So the first pic is how it is now (car running fine) and the 2nd pic is how i thought it "should" have been,any ideas?
Datsun 260c
Re: Help
rblover wrote:All good got the old girl running again
Re: Help
chris_g1 wrote:rblover wrote:All good got the old girl running again
Look to be 180 degrees out as firing order the same. At least it's running now, just enjoy it. Cheers.
