Oops. Need a slave cylinder rod off a 5 speed, 71C type
Posted: Mon Feb 11, 2013 10:57 pm
by broke
As above. I was sure I had it somewhere, but apparently I don't. For a FS5W71C gearbox, I have no idea if the 71B or 63A ones use the same length rod, but if you have one I would appreciate it. Thanks.
Re: Oops. Need a slave cylinder rod off a 5 speed, 71C type
Posted: Tue Feb 12, 2013 7:07 am
I've got a couple, the slaves are different between the C and B boxes but the rod is the same.
Posted: Tue Feb 12, 2013 9:47 am
by brocky41
DJZ, you are like the master for l series parts haha - always seem to have kept the right bits.
Posted: Tue Feb 12, 2013 6:10 pm
by broke
DJZ wrote:I've got a couple, the slaves are different between the C and B boxes but the rod is the same.
O RLY?
In that case, Brocky would be most appreciative if you could supply him one to replace the one that is no longer fitted to his 240C wagon... it must have been taken by either the parts taniwha, or Millie.
