s14 Adjustable suspension?
Posted: Tue Feb 19, 2013 10:03 pm
by Rusty
Is it useful in anything other then a s14. I will be acquiring some this week. Operation CA18DET! has begun
Re: s14 Adjustable suspension?
Posted: Tue Feb 19, 2013 10:24 pm
The front struts use 14mm bolts to attach to the knuckle where S13s use 12 mm ones. Also the rear struts are longer than S13 ones, not sure how much by.
Posted: Tue Feb 19, 2013 10:44 pm
by spiderwebfx
Everything is interchangeable with S15.
Rear toe, traction, camber arms and front castor can be used on R33 and R34.
Coilovers can be used on S14 and S15 obviously. C34 and C35 I think are also compatible.
S13 with 12mm to 14mm sleeves on the S13 strut bolts (to hub carrier).
I have S14 coilovers in the front of my S12, but that's had a bit of hybrid suspension setup on it.
Posted: Tue Feb 19, 2013 10:47 pm
by Rusty
cheers for all the info guys? will get some pics up once we have the ca18det sitting in its new home in my sunny wagon
