Page 1 of 2
no oil preasure in my rebuilt a15? any one got any pointers?
Posted: Sat Mar 02, 2013 2:41 pm
by Dirty D
hey guys. just recently rebuilt my a15 engine and now that its altogether and ready to go i cant get any oil preasure up. it has a brand new oil pump which i primed before i put it in , i also put a tube in the oil pick up and sucked on it to make sure the pick up was working . if you think of any thing that i could use to assist me in this situation it would be much appreciated!! . cheers
Re: no oil preasure in my rebuilt a15? any one got any point
Posted: Sat Mar 02, 2013 3:18 pm
How are you checking for pressure? Mechanical gauge?
Posted: Sat Mar 02, 2013 3:52 pm
by Dirty D
just going off the oil light on the car. pulled the preasure switch out to see if any oil would come out when i turn it over
but there was nothing
Posted: Sat Mar 02, 2013 3:57 pm
That's curious.
I had a really knacker A15 once that had no pressure. But I filled it with lucas/mooreys and it came up really quick.
You haven't done something silly like put standard bearing shells on a reground crank have you?
Posted: Sat Mar 02, 2013 3:58 pm
by torqued
Have you put oil in it
Posted: Sat Mar 02, 2013 4:05 pm
by Dirty D
its got oil in it . i put all new bearings in to fit the reground crank.
i put penrite 15w- 40 running in oil in it which was sugested from the machine shop.
Posted: Sat Mar 02, 2013 4:34 pm
by torqued
My advice: hook up a mechanical gauge see whats what
Posted: Sat Mar 02, 2013 4:45 pm
by Dirty D
yea il grab one from work on monday. cheers
Posted: Sat Mar 02, 2013 10:25 pm
Dirty D wrote:just going off the oil light on the car. pulled the preasure switch out to see if any oil would come out when i turn it over
This doesn't sound like a switch or gauge problem. Sounds like pump isn't supplying, could be air leak in oil pick up, (or not attached), or a fault in the pump, although with the switch being right on the pump even with a faulty relief valve you would expect some oil at the switch.
Posted: Sun Mar 03, 2013 9:14 am
by beaver
Yeh there doesnt seem ant point in hooking up a mechanical gauge if there is no oil at the point you will be testing....
