Page 1 of 2
BUMP STEER SPACERS.
Posted: Tue Apr 23, 2013 4:51 pm
by chris_g1
Got these from e-bay USA, said to be for datsun 510, but the spacing is to wide.
For datsun 510 (or 1600) spacing should be 90mm but these are 100mm spacing.
If anyone needs and has the right spacing these are yours for $30...including postage.
Dimensions are......thickness 25mm
Spacing......100mm
Made from CNC machined billet aluminium or as the yanks say aluminum.
Re: BUMP STEER SPACERS.
Posted: Tue Apr 23, 2013 5:40 pm
by z181200
Does anyone know if they would fit 910 struts? If so Im dead keen. I know they arent the same as 1600 or 1200s maybe these will work for me?
Posted: Tue Apr 23, 2013 5:53 pm
by Naki-Fisher
I'm getting a couple of sets of these made up for my 1200 at the mo 1 @ 15mm 1@ 35mm
Posted: Tue Apr 23, 2013 5:58 pm
by 85_Z31
According to my Old Drawing 100mm bolt spacing should fit a Z31 strut.
how tall is it, and how wide is the spigot at the top ?
Z31-RCA-J TIBBS.pdf
Posted: Tue Apr 23, 2013 6:07 pm
by datsunboy
Hey Chris, Pip will be keen if they match the PDF James posted.
I think 910 struts have the same Billy spacing as 1600s?
Posted: Tue Apr 23, 2013 6:35 pm
by z181200
910 struts seem to be different to others as you can't seem to find any that swap from another datsun.
Posted: Tue Apr 23, 2013 6:44 pm
by MR1200
Naki-Fisher wrote:I'm getting a couple of sets of these made up for my 1200 at the mo 1 @ 15mm 1@ 35mm
how much are they costing bud? i need some aswell keen on getting more made?
Posted: Tue Apr 23, 2013 8:34 pm
910 ate the same bolt spacing as 510, etc. They just run a massive spigot on the steering arms.
Posted: Tue Apr 23, 2013 10:03 pm
by chris_g1
85_Z31 wrote:According to my Old Drawing 100mm bolt spacing should fit a Z31 strut.
Z31-RCA-J TIBBS.pdf
As stated they are 25mm tall.
If you mean by "spigot" the hole in the middle, that is;
Outer diameter...45mm
Inner diameter...32mm
Raised edge........5mm
Posted: Tue Apr 23, 2013 10:07 pm
by chris_g1
Z31-RCA-J TIBBS.pdf
Measured from the bottom edge.
Therefore, looking down from the top the hole is 45mm narrowing to 32mm
