Datsun 1600 S13 front suspension swap??
Posted: Thu May 23, 2013 8:12 pm
by gingofthesouth
Does anybody have any info on modifications needed to be able to run s13 struts in the FRONT of a Datsun 1600??
I am going to buy a set of S13 coil overs to fit the the rears, but what to do with the fronts?
Re: Datsun 1600 S13 front suspension swap??
Posted: Thu May 23, 2013 9:43 pm
by sr1600
Buy the strut setup that dan brought of MRP tempted to buy a set myself, I'd be interested in the rear s13 coil over length I've brought some Honda ones and remade the top hats to suit 1600 fit sweet but wound all the way down I'm about 30 mm off tucking a 15
Posted: Thu May 23, 2013 10:30 pm
by broke
Do you want to swap to the whole S13 style front strut, brakes etc or just fit coilovers easily? If you want the S13 whole setup you need the control arms and hubs as well as they mount in a totally different way. This will also widen your front track significantly.
If you just want to use S13 coilovers because they're cheap and common then you want to buy some body adjustable ones and unscrew them from the S13 hub mount. Then you cut the strut tube off your 510 hub and get threaded sleeves to suit welded on.
Not a 510, but here's a link to a guy's thread where he did it on a Celica Supra:
http://driftoy.proboards.com/index.cgi? ... thread=210" onclick="window.open(this.href);return false;
And here's a nice thread on how to get S13 rears fitted to a 510
http://www.the510realm.com/viewtopic.php?f=29&t=23675" onclick="window.open(this.href);return false;
Posted: Fri May 24, 2013 1:25 am
by gingofthesouth
sr1600 wrote:Buy the strut setup that dan brought of MRP tempted to buy a set myself, I'd be interested in the rear s13 coil over length I've brought some Honda ones and remade the top hats to suit 1600 fit sweet but wound all the way down I'm about 30 mm off tucking a 15
MRP?
broke wrote:Do you want to swap to the whole S13 style front strut, brakes etc or just fit coilovers easily? If you want the S13 whole setup you need the control arms and hubs as well as they mount in a totally different way. This will also widen your front track significantly.
That thread for the rears is what I have had my eye on.
For the fronts, that other link is cool idea, I will look into it.
Thanks for the info peoples. I appreciate it.
Posted: Fri May 24, 2013 11:29 am
by sr1600
dan1200sss wrote:My custom super low adjusties from MRP up north just arrived, he had to have shorter than normal inserts ordered in for them. They are body adjustable to so can lift it up and down without touching the spring tension if need be.
Manon racing products sell a weld on strut as attached from dan1200sss's 510 thread
