Ld28 won't go
Evil13
aka: kane
Ld28 won't go
Post by Evil13 »
Did a manual conversion and timing belt and now it won't go I put belt on B mark of pump and then fitted to the crank where the mark is leaving 20 teeth between the points on the belt. I just read that it shouldn't be 20 unused teeth it starts and finishs on the marks of the pullys
Can anyone help?
1200 sedan
1961 ford galaxie
aka: leppa
Re: Ld28 won't go
Post by dirtyleppa »
did you compare the belts before fitting? if you are 1 or 2 teeth out most diesels will struggle to run if at all. did it run before you did the manual conversion and after changing the belt?
brocky41
aka: Brocky
Re: Ld28 won't go
Post by brocky41 »
Have a read on this
http://nissandiesel.dyndns.org/viewtopi ... sc&start=0" onclick="window.open(this.href);return false;
Evil13
aka: kane
Re: Ld28 won't go
Post by Evil13 »
My pully on the pump is different to that mine is the same as the one in the bottom post of this
http://nissandiesel.dyndns.org/viewtopic.php?t=1105" onclick="window.open(this.href);return false;
1200 sedan
1961 ford galaxie
brocky41
aka: Brocky
Re: Ld28 won't go
Post by brocky41 »
Did your néw belt have the two white lines coz I just lined those up with the marks
Evil13
aka: kane
Re: Ld28 won't go
Post by Evil13 »
No belt had no marks I got it going today has a bad whine somewhere now tho
1200 sedan
1961 ford galaxie
