Page 1 of 4
wtd. r200 conversion parts for a 510
Posted: Tue Jul 02, 2013 8:03 pm
by oldskooldat
im looking at buying a 510 with an overpowered engine with a standard diff. i wont buy it unless i can upgrade the diff.
does anyone happen to have an r200 lsd diff and parts needed for a 510 for sale
can someone tell me the rough cost of the conversion.
cheers
Re: wtd. r200 conversion parts for a 510
Posted: Tue Jul 02, 2013 8:12 pm
Modified axles run into about 300.(If you can find someone to do them for you) I'd say $80-100 for HR30/910/etc outer companion flanges.
I don't know what you'd expect to pay for r30/s12/910 outer CV's. They may even be available new. (at a cost)
Then you'd need to find a longnose R200. (Others might have an idea what market value for those is)
And a shortnose LSD and inputs. (Either VLSD, or CLSD) VLSD's can be picked up pretty cheap.
It would have to run into around the $600 mark all told?
Posted: Tue Jul 02, 2013 8:53 pm
by 85_Z31
It also requires mods to the cross member to fit the R200 in place.
Posted: Tue Jul 02, 2013 9:20 pm
by torqued
Diff Bracket
Posted: Wed Jul 03, 2013 12:59 pm
by dan1200sss
Budget minimum $1k all up I'd say TBH
Posted: Wed Jul 03, 2013 2:35 pm
by pl510
Agree
As the boys said,
Modified axles
Longnose R200
Shortnose LSD and inputs.
Moustache bar and mods to crossmember
Plus possible driveshaft mod depending on flange dimensions of R200
Fly up and have a look at it.
Posted: Wed Jul 03, 2013 3:04 pm
by oldskooldat
Ill b happy enough with paying a 1000. Who's got a setup they would sell
Posted: Thu Jul 04, 2013 8:23 pm
I have some replica outer companion flanges.
I say replica, as they were the standard UJ ones. The square end was machined off, then a locating spigot was turned on. Then copies of the R30/etc flange were machined up, and they were welded together. How strong are they? Tbh, I don't know. They look pretty strong though.
Posted: Fri Jul 05, 2013 12:29 am
by Rusty
oldskooldat wrote:im looking at buying a 510 with an overpowered engine with a standard diff. i wont buy it unless i can upgrade the diff.
cheers
I have a rear subframe less diff from s14
Posted: Fri Jul 05, 2013 8:46 pm
only the inner CV's are of any use.
Are they 3x2, or 5x1.
