WTB 310 Sunny front shock bump stops
Posted: Tue Nov 19, 2013 3:47 pm
by Kitch
As per title after a pair of the rubbery foam bump stop rings, that go on the front shock shafts.
Need to reduce the clunking in the 310!
Re: WTB 310 Sunny front shock bump stops
Posted: Tue Nov 19, 2013 6:19 pm
by mint16
Autolign bud.
Posted: Tue Nov 19, 2013 7:48 pm
by brocky41
Kitch wrote:As per title after a pair of the rubbery foam bump stop rings, that go on the front shock shafts.
Make sure its not the sway-bar overextending itself into the chassis (in the middle of the bar in-between outer links and first 90 degree curve, this used to happen on the Y and the 1200.
Otherwise we sell them at BNT aswell - be closer for you down there
