dual axle vs single axle car transporter
Posted: Wed Jan 08, 2014 11:54 am
by torqued
ANyone have any useful information to contribute to dual axle vs single axle car transporter?
Pros / Cons?
Open road long distance sort of thing
Re: dual axle vs single axle car transporter
Posted: Wed Jan 08, 2014 12:23 pm
by 85_Z31
I am a fan of double axle Transporters
In my limited experience single axle's seem to be a bit shorter and lighter construction and Usually Not braked
Double axle's tend to be braked and tow a bit better.
I can send you a photo of my old mans double axle with steel deck for reference if you like.
Posted: Wed Jan 08, 2014 1:52 pm
by torqued
Na I know what a trailer looks like, THanks tho.
Just really after peoples opinion
Posted: Wed Jan 08, 2014 2:02 pm
by broke
Doesn't matter as long as you let me borrow it whenever I want for free.
Posted: Wed Jan 08, 2014 2:10 pm
I think I've only ever towed with dual axle ones, never really had a problem apart from when you want to move them around by hand.
Posted: Wed Jan 08, 2014 5:50 pm
Yeah Tandems are not as easy to live with around the section, harder to manoeuvre around by hand. On the road the Tandem tows better, although is harder on tyres if you are manoeuvring them around a lot. Depending on what you are towing with you may not notice the difference. Early on I always used a tandem, lately I have only used a single, and towing the Zed to Timaru behind the Commodore was fine. The Zed isn't heavy but still it isn't a 1200 and the single axle towed nice at the speed limit. Even unbraked it was very comfortable.
I have wondered the same question, and think if I was to build my own it will come down to what storage I have, if the car needs to sit on it at all times it will probably be a tandem, or I would consider a single with a jockey wheel, my preference would be a single just for the ease of manoeuvrability.
Posted: Wed Jan 08, 2014 8:51 pm
Depends on what you're towing.
For a small car (Most datsuns, apart from the ceddy's) A single is okay.
Posted: Thu Jan 09, 2014 10:10 pm
by SRDATO
Towed both, singles tend to make the back of you car bounce up and down more as they pivot on the one axle but hold the road reasonably similar, one thing I like about tandem is if a wheel bearing collapses or tyre blows you still have a extra wheel on that side to stop things getting hairy and get get you home.
Posted: Fri Jan 10, 2014 10:24 pm
by kartboy
If you have a tandem with a jockey wheel, wind the jockey wheel all the way down (or until the front wheels are close to off/off the ground) It then can be maneuvered a lot more easily
