Alternative brakes with 89mm mount
Posted: Fri Jan 24, 2014 5:36 pm
by gingofthesouth
So I have r31 struts and brakes with 89mm mount.
The flat mounton my 15 inch star sharks hit the brake callipers.
What are my options to replace the callipers with a lower front facing profile that will mount on these shocks?
Re: Alternative brakes with 89mm mount
Posted: Fri Jan 24, 2014 5:53 pm
by torqued
Edit* to shrink the picture
Im running S4 RX7
Posted: Fri Jan 24, 2014 6:05 pm
by gingofthesouth
Thanks Adam. They certainly look like they stick out less than my clunkers!
Check out the surface rust on these bitches. Shows how long it has been since they have seen some use. Had them machined 3 years ago now!
Posted: Fri Jan 24, 2014 6:20 pm
by 85_Z31
Datsunboy was able to find some rotors with an unusually tall hat for spoke clearance. But other than that his setup is totally different.
Posted: Fri Jan 24, 2014 9:51 pm
by sr1600
Yeah yours are r31 front struts/brakes
    Where as torqued (adams?) are a volvo disc? with a mazda caliper and a b310 style hub..
    Mine are same setup as adams but with gtst calipers and discs, I snuck a 5mm spacer between the hub and the brake disc, all on the r31 strut...just means that you need to make some brackets to mount the calipers.
    Posted: Fri Jan 24, 2014 10:21 pm
    by torqued
    sr1600 wrote:Yeah yours are r31 front struts/brakes
      910 hubs
      Some sort of Vtec honda disc (i have part number somewhere)
      s4 RX7 calipers
      Lemme know Ging dude if you need anymore details. I gotta get them sitting slightly more flush so going to revisit the bracket shortly
      Posted: Sat Jan 25, 2014 7:58 am
      by sr1600
      Whoops 910 hubs
      When I looked into going rx7 calipers, I looked into the disc sizes and found apart for the obvious fd3s and fc3s disc there was others the same width
      E30 BMW+ a couple of others, Volvo 740?? turbo I think and some honda prelude form memory all with various different disc heights.
      If anyone has some 910 hubs they want to sell I'm on the lookout for another pair
