Page 1 of 2
Right Front Suspension Strut
Posted: Mon Apr 07, 2014 10:42 am
by M1SSI0N
Hey guys I'm could be after a right suspension strut for my car.
I have a 1981 Datsun Sunny GX b310, if you after more info just ask. I would profer it be South Island to make costs bit cheaper.
Re: Right Front Suspension Strut
Posted: Mon Apr 07, 2014 12:26 pm
by Kitch
you after the insert or strut housing itself with stub axle etc?
Posted: Tue Apr 08, 2014 11:57 am
by M1SSI0N
Sorry warrant man got it wrong, it's a shock that I need
Posted: Tue Apr 08, 2014 1:29 pm
by Kitch
I have some surplus original oil filled type 310 strut inserts if they are of any use to you?
Posted: Tue Apr 08, 2014 1:50 pm
by M1SSI0N
Yeah it could be. You don't think you could put a photo up so I can make sure it's right ?
Posted: Tue Apr 08, 2014 3:54 pm
by Kitch
Do you have oil filled inserts or gas?
If oil filled, you can overhaul what you have I guess - or best to throw an aftermarket insert in each side.
Posted: Tue Apr 08, 2014 4:11 pm
Kitch wrote:Do you have oil filled inserts or gas?
Really important for handling that these work together, a Pair of inserts would make a huge difference to the handling of the car, and it's ride
Posted: Wed Apr 09, 2014 11:24 am
by M1SSI0N
It is oil filled. How much are you after for the right front one ?
Posted: Wed Apr 09, 2014 1:04 pm
by Kitch
Why did it fail WOF?
Can you not just strip down your one and clean up, put back together and refill the oil with ATF?
My spares are stripped down, so would be no difference to re-using what you have, unless the dampening valve has failed?
Posted: Wed Apr 09, 2014 4:33 pm
I'd just buy new gas inserts and be done with it.
It'll really make it drive heaps better too.
