LSD Troubles
Posted: Mon Apr 14, 2014 9:12 pm
by Adam Herbert
What LSD's can i put in my 1974 1200 sedan?
Re: LSD Troubles
Posted: Tue Apr 15, 2014 12:29 pm
There is no very straight forward cheap option.
A hilux back end is probably the easiest to source. But it will need cutting down, hubs redrillng etc.
You might be able to find an LSD for an H165, (1200 ute diff) but these can be hard to find too. (Not sure if they're still available new or not)
Re: LSD Troubles
Posted: Tue Apr 15, 2014 6:13 pm
by jmp
Hey man
Its not an easy route to go down, i have been looking into it for my Ute for ages.
Bolt in LSD's for h165 1200 Ute diffs are almost impossible to come across but there
is a guy in Aussie who used to manufacture torsen type ones but not cheap. The easiest
way is probably to re-drill a 1200 Ute diff housing to fit an ae86 LSD head. A company in Auckland
will do it for around $1000 plus gst including the LSD if you don't want to do it yourself.
Re: LSD Troubles
Posted: Fri Apr 18, 2014 12:07 pm
A guy down here in chch 72_1200 did it fairly simply by the sounds of it, its on his members rides thread, using the Toyota centre,
