Engine Mounts of A15
Posted: Tue Jul 22, 2008 10:06 pm
by my1200
I require A15 Engine Mounts, I have a A14 and A ute Cross Member Hence the Problem.
If you have or know someone please contact me.
Re: Engine Mounts of A15
Posted: Tue Jul 22, 2008 11:35 pm
by Dattodevil
Why not just use your coupe cross member with the A14? Or are they not the same as an A12?
Posted: Wed Jul 23, 2008 9:01 am
by cheater_5
late model a12 (from a ute) a14 and a15 use same engine mounts and "ute" crossmember to fit to 1200.
Early a12 (b110) use different mounts and (b110) crossmember to fit to 1200.
Making sense at all? dont think i frased it perfectly.
Posted: Wed Jul 23, 2008 12:27 pm
by my1200
No the standard Cross Member requires a mount that is ugly,
I want the enginr to sit perfectly and was told that the ute
cross member is the go.
My brother informs me that A15 engine mounts ie the metal part
bolts onto the A14 and then the engine mounts will line up spot on
to the ute Cross Member?????
Is this So??
Posted: Wed Jul 23, 2008 2:56 pm
by cheater_5
sure is boss
Posted: Wed Jul 23, 2008 4:40 pm
by my1200
thanks, like I say if anyone has some keen as mustard.
Posted: Thu Jul 24, 2008 7:49 am
by Dattodevil
my1200 wrote:No the standard Cross Member requires a mount that is ugly,
Is this So??
Sweet, will insert that into the memory banks....................Download completed.
Posted: Fri Jul 25, 2008 2:49 pm
by my1200
computer says no
