R33 Dash cluster
mark105
Datsun Dreamer
aka: 10 5
R33 Dash cluster
Post by mark105 »
im putting an rb25 in to my 260 and im using the dash cluster also but i noticed that it doesn't seem to power up the dash cluster till i hit the start key position when i first turn it on, its not powered up at key on which i think its supposed to (oil lights, charge lights and so on all aren't lit at key on until ive hit the start circuit), once you hit the start circuit and are cranking even if it doesn't start every things on but im not sure if this is normal or not. Im using a striped down full loom from the R33 which i did.
can any one with a skyline confirm or deny when the dash powers up?
also does any one have a R33 wiring diagram as this would be handy.
