Parts Hoarder Sale!
Posted: Sun Oct 12, 2014 9:01 pm
-1600/P510 L16 Nikki carb, manifold, airbox $60
-1600/P510 'DATSUN1600OHC' rocker cover $50
-1600/P510 front grille x2 $30each
-A12 flywheel x2 (ideal for lightening to fit on your A12/A14/A15) $30each
-A12 2-bolt front pipe that fits to exhaust manifold $10
-A15 H89 head, has been lightly skimmed, off good running stock A15, $120
-A15 H89 head from c22 motor, fresh valve grind, crack and hardness tested by Mace Engine Reconditioners, dip cleaned, surfaces skimmed $300ono
-A15 crank x2, good condition journals $40 each
-A15 bare block with caps, no lip on bores $30
-A15 bare blocks with caps, front cover, crank, crank pulley, cam, no lip on bores $50
-A15 pistons and rods SET x2 (1 set missing a bearing cap, condition of pistons unknown) $40set
-Sunny/B310 20mm front swaybar x2 (upgrade for any Sunny with A12 motor) $20each
-S12 Silvia FJ20E front and rear 25mm swaybars with bushes and mount brackets $20each
-S13 180sx CA18DET front 25mm swaybar $20
-280zx front crossmember, lower arms, engine mounts, swaybar, caster rods
-1600/P510 22mm front swaybar $40
-1600/P510 driveshafts (factory or shortened length) $30each
-140J rear axles and H165 diff housing with brakes (suitable for Sunny B310 wagon H165 diff upgrade) $50
-S14 Silvia rear seat $30
-R32 GTR front and rear seats $600
-R33/Stagea 4stud twin-pot front brake calipers and 272mm discs $50
-CA18 ecu x4, cas x3, igniter, resistor, motor looms x2
-RIVERSIDE R106 wheels 14x6.5 0offset 14x7 -5offset $800
-BELLS Racing wheels 14x6.5 +4offset 14x7 -2offset $800
Photos can be uploaded if interest shown, cheers!
