Page 2 of 4
Re: seat mount fabrication
Posted: Sat Jul 26, 2008 1:16 pm
by MONTY
ok here's a pic of what we did to seans car not the best pic but you get the idea of the box secton etc
Posted: Sat Jul 26, 2008 4:01 pm
That might be compliant for a race car, but it wont pass cert for a street car.
Posted: Sat Jul 26, 2008 5:16 pm
by IIIRII
Why not
Posted: Sat Jul 26, 2008 6:14 pm
The NZ hobby car technical manual says new brackets must be bolted to the floor. There's a chapter relating to sizes of doubler plates and the like, but I've never studied it too closely. (too much reading)
Posted: Sun Jul 27, 2008 7:16 pm
Barts quite correct, the seats if mounted to the floor MUST be bolted through it, you can however mount the seats on pieces of box section, that span between the sill and trans tunnel, however the box needs to be bolted to the sill and trans tunnel, then the seat can be welded to the box, seat belt mounts are deemed sufficiant to bolt the box to, basically its major BS especially as you can weld the seat to the box , but must bolt the box to the car . :shock:
Posted: Mon Jul 28, 2008 9:58 am
by IIIRII
On the 310 it has 1.6mm steel rails WELDED across between tunnel and inner door sill, with reinforcing plates.
The seats are on ally brackets that bolt to the welded in position rails.
Both cars comply and are certed and have auth cards
Posted: Mon Jul 28, 2008 5:05 pm
by MONTY
i went to see the cert man today about it but he wasn't there damn it!
by MONTY
Posted: Mon Jul 28, 2008 5:38 pm
IIIRII wrote:On the 310 it has 1.6mm steel rails WELDED across between tunnel and inner door sill, with reinforcing plates.
Perhaps different cert men have different ideas?
Posted: Mon Jul 28, 2008 9:14 pm
by nick_m
Its pretty clearly laid out in the documentation whats required for a street car as Bart said, but where it may get fuzzy is for rally cars, I don't know i'm just guessing as i have never owned a rally car let alone taken one through cert. I do know that Palmside get a few more liberties than the average joe.
But like you say at the end of the day it comes down to what the Cert man is willing to sign his name against.
Maybe you found a loop hole because technically its not welded to the floor :)
