For sale is the complete supercharger set up off my A15.
Complete with toyota S/C14, 350cfm 2bbl holley carb. Carb has externally referenced power valve, and an "anti syphon" kit from Mclendon carburator in tenessee fitted to the Accelerator pump nozzles. Custom three piece crank pulley. And duratorque tensioner pulley. Also has manifolding etc, and blower mounting bracketry.
Bolt this set up to your A15, and you could expect it to make around 11psi.
My datsun 1200 sedan ran a 14.1 with this set up.
I'm not sure how reliable it might be on an A14, or A12 as the boost would be higher due to the smaller swept volume.
No-one who rode in my car ever said it was slow.
I'd like $1500.
A15 supercharger kit.
- blitzballa
- aka: James
Re: A15 supercharger kit.
What type of power did this setup make on your A15?
- D1RTY6
- aka: Nathan
You should convince Nathan to buy this for his ute!
Sadly It wont fit Nathan's engine Nathan.
Bitzballer, here's the only dyno sheet I ever got with this set up on an engine,
http://datsun1200.com/modules/newbb/vie ... post190551" onclick="window.open(this.href);return false;
http://datsun1200.com/modules/newbb/vie ... mpost56706" onclick="window.open(this.href);return false;
