Tractionbar
Posted: Mon May 25, 2015 7:13 pm
by Ivan
So I was looking at Yahoo Japan and found a listing for traction bar's. Not knowing on what they did I looked in to it more. Has any one used them on there leaf spring rear end?
I have some 5mm thick angle iron and thinking about making my own. Any thoughts?
Re: Tractionbar
Posted: Mon May 25, 2015 7:49 pm
by brocky41
all the ones ive seen a full box section - not angle iron - rubber stops would be easy enough to source
Re: Tractionbar
Posted: Mon May 25, 2015 8:12 pm
by dirtyleppa
I would imagine they would be to stop axle tramp thia increasing traction? I think the only real need for these is if you were doing alot of drag racing or big clutch dumps.
Or if you have massive blocks or reset springs
Re: Tractionbar
Posted: Mon May 25, 2015 9:43 pm
by brocky41
Try this - not great for lowering
http://www.hotrodsandhemis.com/Traction.html" onclick="window.open(this.href);return false;
Tractionbar
Posted: Tue May 26, 2015 4:37 am
by kobyn
Yeah they work real well for me as I dump clutch a lot lol
Re: Tractionbar
Posted: Tue May 26, 2015 6:55 pm
Unless your getting axle tramp now, you don't need them.
Re: Tractionbar
Posted: Sat May 30, 2015 5:49 pm
by Ivan
You may be right Baart, I'll have to get the old girl going to take her out for a spin.
Re: Tractionbar
Posted: Wed Jun 10, 2015 7:37 pm
by nzbidzel
brocky41 wrote:all the ones ive seen a full box section - not angle iron - rubber stops would be easy enough to source
agreed here, just get some 50x50x3 RHS, with some Ubolts n a rubber stop donor, but id do a watts link or similar before even remotely considering these, as they are pretty much drag use only
